Rear end oil leak
i have gear oil leaking out of the rearend of my 84 Craftsman GT/18 18hp twin cylinder Mod# 917.253744 by the hubs any suggestions as to what I can do and if so where can i find the parts to fix it
jroske
I tried to lookup that rearend on Searspartsdirect.com but that rear end is not listed anymore. My supplier cannot even get it anymore. Send me the make and model of the rear end and I make be able to find some seals for you. The make and model is no longer listed on the website. you can email me at joesmowerservice@gmail.com...
where can i find the make and model of the rearend?
jroske
That is a good question.. Not knowing the manufacturer of the rear end it could be anywhere.. You might look underneath first.. You may have to drop it to find it unless you have the original books that came with the machine.
i have an owners manual for the tractor it did not come with this machine but it is an owners manual for its model will this help in finding the info you need
jroske
It may, it depends if it has a parts breakdown of the transaxle.
yes it has a Sears parts breakdown and it says it is part# 7393R and the part# for the transaxle is 10134R if it helps
