Richie F
- Aug 8, 2019
- 19
- 276
I have a rear 2 bagger that was made in 1999.
When grass is being cut the left bag fills first and then the right, but I feel the right has a collection problem.
I feel both bags should fill equally as I cut. Not have one bag fill and then overflow into the other.
Would like to see pictures of later model bagger hoods on the inside to see the design and see if there is a difference in hood design or shoot nozzle.
I have a wire mess baffle on the hood and an exit for air on the right.
I have the proper high lift blades on the deck and the belt is good.
Bottom of deck is clean and so is the chute.
