mechanic mark
- Jul 15, 2013
- 175
- 7,381
Brushing anti-seize compound on rear axles is most often overlooked. Use jack stands for Safety. Remove hubcap & hardware, wheel, spacers, key, etc. until you're down to axle shaft. Apply anti-seize compound with small brush covering axle completely. If you see any rust you may want to remove it before applying anti-seize with emery cloth, scotch bright pad, etc. This procedure will prevent moisture, rust, etc. from seizing parts to axle shafts in the future.
