Good afternoon,
I’ve got a Hustler Raptor SD that is extremely difficult to go into bypass on the left hand side. This is also the side that I had a cracked rear mounting bracket on. The same bracket that has the bypass lever running through it. After replacing the brackets, I noticed that SPECIFIC bracket was about half a hole off from lining up with the hole in axle itself. Is there another way to put the mower in bypass? I’m bending the circular part (now oval) of the lever trying to get one of the notches to lock in on the bracket to keep it in bypass.
