Mower deck Raise Mower deck YT4000
dcr465
my yt4000 cuts grass at about 3" in highest deck position. any way to raise deck to reset deck positions??
thanks!!!
lawncutter
Yes
I have the same model tractor, mine is out of warranty so you may or may not want to do this mod, on the front tab of the mower deck there is a rod connected to the top hole to a tab, notice the bottom hole is not the same size hole as the rod size on top. I just drilled it out and used that hole. Mower works fine now
