Does anyone have experience with removing the quick change blade assembly and replacing it with a five star adapter? A lot better blade selection is available!
Yes but you will have install new spindles. Still way cheaper trying repair the quick change blade adaptors when they are bent. They were around $152 each vs $35 spindles on the last unit I changed over..
What is the model number of the mower from serial number decal?
I have a YT46LS, I want to replace the spindles to eliminate the quick change blade system. What part number spindles do I need to get to accomplish this?
