Hitechluddite
- Dec 14, 2018
- 24
- 90
This looks to be a well cared for tractor 880hrs. Deck is solid all lights and controls work. Only problem so far is it won't start when cold unless you give it a small shot of starting fluid in the air cleaner then it fires right up. There is a small puff of whiteish/gray smoke when it cold starts but only lasts for a second then the exhaust is clean. The Trans is a little noisy when it climbs a steep hill but it doesn't lose speed. The cruise control holds speed but never at the speed you set it to, it always drops back about 25%. I'm going to try and locate a manual tonight and start studying but would appreciate any advice on the listed problems
