Most likely not hurt. May need to do the air purge procedure. Jack up the rear wheels, pull the bypass, start the engine and run on idle and move the direction control slowly back and forth several times. Then engage the drive and do the same back and forth with the direction control. by this time the wheels should be turning without any load. Then let the wheels down and see it if will drive.
