PTO Won't Engage When Hot.
greendohn
Simplicity Prestige Model# 1694017, Serial# 03074, about 600 hours on the clock.
Starts/runs great, PTO engages as it should until it's been mowing for a while, stopping for a minute and the PTO will not engage the mower deck until it sits for 10/15 minutes then it will engage as it should.
Replaced the PTO switch with new Simplicity unit which has not resolved the problem.
(didn't find what I was looking for with the Search Function)
roast me if I have missed something here...
Sounds like the clutch plate are out of adjustment. Do you have the clutch with the triangle shape with the stud spring and nut in each corner. If so insert a .012 feeler gauge between the two plates and turn each nut slowly until you get the same clearance at all three corners.
greendohn
^^ Thanks, ILENGINE^^
Found a couple vids on pooptube that showed me how to do as you suggested.
