PT 460/ Deck Height Selector Wheel
JJWILLI
I have a 2020 Gravely Pro Turn 460. Ive noticed when cutting between 2.75 and lower my selector wheel will drift lower from its locked position. I cant really tell if the deck is moving with it or not because its a gradual drift. Has anyone had this issue?
MParr
Go back through your operators manual and read through the part about leveling, pitch and setting height adjustments. Make sure you do this first. There’s also a section about adjustment of springs to adjust the response of the up and down function of the deck.
Contact you dealer and Ariens support after you have performed all of the above, without results. Your mower is under warranty.
