I purchased used, procut 61' ( PN 5900533) with Kawasaki engine.
I'd like to disengage the hydraulic pump and remove the deck to treat any rust each winter.
I've got the owners manual and setup guide, the setup guide shows deck assembly and disengaging the pump. It shouldn't be too hard to reverse deck assembly, but the hydraulic pump instructions (push the rider by hand) and image aren't very clear. I'm pretty sure I found the hydraulic release value, but accessing seems very difficult. I almost feel i need to remove stuff to get to it.
Anyone know of additional resources or have tips to disengage the hydraulic pump and deck removal?
Thanks
Thanks
