I had a spark plug blow out of the engine, damaging the threads. I've got a combination tap/reamer that's supposed to remove the old threads, and cut new ones, so I can screw/loctite an insert into the new threads to hold the spark plug. I watched a few videos that make it seem pretty straightforward and simple; the tap engages the existing threads, and the torque applied to the ratchet removes them and cuts new ones.
The problem I'm having is that the tap doesn't seem to be engaging the threads. It's cut most of them out, but that seems due to inward pressure I applied to the ratchet in an attempt to engage the threads as opposed to the threads themselves engaging, and the reamer doesn't seem to be getting any purchase to cut new threads. Now all I'm really doing is just spinning the tap without any real result.
I don't know if I've got the wrong tap/reamer, used it incorrectly, didn't realize how much pressure the guys in the videos were applying, or what.
Any help or advice would be very much appreciated.
