My deck belt started coming off when I ingage the blades so I thought the belt was stretched and bought a new one but I am having same the belt seems like it's a little sloppy when I lower the deck and ingage the blades with the motor not running I know for a fact it's the right belt and that it's on correctly I looked for an adjustment of some kind but the only adjustment is for the deck itself could the spring load tension pulley that has the cable on it be weak? The info on mower is 2016 MTD Yard Machine model number ( 13B2775S000) it's a 42" cut it has a power more OHV motor420cc
