hello
my 8 yr old pro turn52 with 500 hours wont start
it does click but when i hold key on start it starts smoking (somewhere around starter)
this all began when i deduced it was running on one cylinder
i changed plugs then fuel filter air filter...
none of this helped so
i relaced both coils before i noticed the fuel solenoid on bottom of carb bowl stayed hot when key was on (and the ground battery cable - warm)
i found one small wire chewed and starter cable boot chewed up at starter. i repaired that wire and insured the ignition cable end was not touching anything
please help thanks
please help thanks
