Pressure Switch Kawasaki Ninja Washer?
c11488
I've got a Kawasaki Ninja 2000 PSI Electric Pressure Washer that's been a great little machine. The model # is 692665 and its made by AllTrade Tools.
One day it started leaking and I discovered the pressure switch plastic nut cracked off so it wouldnt ever shut off the machine. I'm trying to find the replacement part for this because it seems like an easy fix for a machine that otherwise worked great before. The Switch has writing on it of PA66+30GF
Any help is appreciated. Some pictures attached for reference.
Thanks in Advance,
Mike20220424_141138.jpg20220424_141207.jpg20220424_142701.jpg20220424_143954.jpg20220701_220044.jpg20220701_220049.jpg20220701_220054.jpg
After searching for 20 minutes I suggest you contact All Trades Tools at this number, 1-800-590-3723
sgkent
c11488
First Post. Is a direct copy of a post at https://www.powerequipmentforum.com/threads/pressure-switch-kawasaki-ninja-washer.25570/ back on July 1.
PA66 GF30 stands for 30 % glass fiber reinforced PA 66. There is a huge sticker on the side of it that says for service call the number listed in the last post. Not really sure if this is a genuine thread or not or the pretext for spam.
Thanks for replies...
This is a genuine thread and I posted here as I saw no replies in the other forum. If they are one in the same site, then I apoligize as I did not know this. I avoided posting here originally as I thought it was focused on lawn mowers only, but since saw discussion about pressure washers although much it seems to be based on gas engines versus electrical.
I have contacted AllTrade previously with no repsponse (and again this week) thus I decided to post online for assistance as well. I am guessing based on the age of the unit and lack of any Kawasaki mentioned on their website they no longer support it. Even though pressure washers vary on the outside, I figured the internals must be fairly common and hoped someone had seen the same issue I have. I have opened other units, but they have slightly different designs/parts so still no luck finding a part number that would replace this component. Hate to waste a machine in the landfill for this reason if I can avoid it.
