- Sep 24, 2017
- 250
- 6,437
Need a new Drive wheel, teeth are stripped out. it's for an older gentleman so both wheels working helps out alot
i'm finding
Stens doesn't show a part for it, however i found this one
It's the same dimensions, 8X1.75" with a 1/2" bore. 53 teeth,
The Caveat, 1/2" bore... i'm pretty sure i need a 5/8" bore. and i don't think they make a 1/2" to 5/8 hole adapter
unless i have enough material to drill it out, but it may compromise the integrity of it.
Stens doesn't show any 5/8" bore drive wheels.
All rotary has are 1/2" bores...
i get a 500 internal error when i try to search Prime Line...
Oregon, nada.....
All the ones on Amazon are 1/2" and 3/8" bore
no junk ones to swap off of.....
i'm finding
Husq,AYP 581009405
but NLA anywhere. Parts tree says ships in 4/8 bidness days, so that usually means they don't have it, jacks "appears to have it" so i may try to give them a ring. other places say Discontinued.Stens doesn't show a part for it, however i found this one
205-724 Drive Wheel
www.stens.com
Oregon, nada.....
