PTmowerMech
- Apr 16, 2018
- 396
- 3,016
The spring under the hub on this saw... When I tighten down the screw that holds it to recoil, it tightens everything down. When I keep the screw loose enough to pull the recoil rope, after a few pulls, the recoil is tight again.
I'm not missing any parts, as seen in this diagram. 33 through 36.
What am I missing? Why does the recoil not recoil.
I replaced the "hub spring," (part number 581481601) because it was smashed out of shape. But that didn't really change anything.
The recoil spring is still in good shape.
