It will start the first pull and run for a few min. I have used new gas, oil, air filter, spark plug, even cleaned out the carb float, bowel and main jet they where all pretty clean. I think it's something with the low oil sensor. I have disconnected what i think is the sensor it is a yellow wire that goes into the side of the motor into a bolt to replace it.
There are some other wires that go to the bottom of the carb. I'm not sure what they are for see pics below.
