Poulan Pro self propel push mower
Scrubcadet10
Moderator
Staff member
The gearbox went out for the self propel on the push mower, so i typed the model # from the tag into jacks small engines and nothing comes up.. i've tried these 2 numbers
961220003 & PR45YTTSP
any help to locate parts would be appreciated!:smile:
Let me correct your model number it is a PR45Y22SP which could be a 96122000300 or 96122000301
type those numbers into this website and it will give the IPL for your mower
http://www.poulanpro.com/us/support/owners-manuals/
Both numbers show the same gearbox so either IPL should work.
Scrubcadet10
Moderator
Staff member
Thanks ILENGINE! :thumbsup::thumbsup:
Scrubcadet10
Moderator
Staff member
well i thought the gearbox went out, pulled it off and opened it up this evening, turns out the shaft the pulley goes onto is supported by a ball bearing, the ball bearing came out of the little pocket it sits in somehow!, so i cleaned it up and put some Loc tite bearing mount adhesive stuff around the outside edge of it and hammered it back in gently, felt snug going in, and resealed the case with some permatex gasket maker.... we'll see how it goes!
letting the loctite and gasket maker set up and adhere before i use it.
