Poulan PRo PB 22VA48- Steering wheel has play
Freedom
Hello all
I have a Poulan Pro 22HP (240 hours) and the steering wheel has a little play.
I saw some video in you tube and maybe the problem could be:
item 21
586 84 02-01 Adapter Wheel Steering
or
the bushing , I think is this part:
item 22
585 02 99-01
Bearing
Any ideas ?
I would like to buy the part before the disarm of the lawn mower
thanks!
F
The adapter wheel steering normally causes a floppy steering wheel due to movement between it and the steering wheel, and the nut/bolt that holds everything tight keeps coming loose.. The bearing will cause some wobble, but is not a common part for failure unless it gets badly worn. You will see the egg shaped hole when it gets worn.
It all depends what play it is. There is several areas that cause problems from worn bushings and draglinks too. But it is the steering shaft just flopping around then the 532195228 Bushing Steering is probably the culprit. It is just a plastic bushing sitting in the upper operator tower.
Item 177
Freedom
thanks STAR ! I Where could I download that manual? I have another one but incomplete
