Forgive me if this has been asked-and-answered before, but I could not find a prior discussion.
My Poulan PO17542LT tractor (mechanically identical to some Craftsman & Huskvarna models) has shifted "hard" since putting on a new drive belt. Symptoms are if left running with the parking brake engaged, the drive belt "smells/cooks" after 15 seconds or so. Clearly the belt is not moving but is also too taught against the drive pulley. Then, when running but stopped with the clutch fully depressed, I cannot move the shifter to any different gear, yet when the engine is off, the shifter moves easily between gears.
The only adjustment I can find is at the brake, adjusting the distance of the compressed spring. I have tried "tight" (1-3/8 inch) and the brake engages quickly while releasing the clutch causes an abrupt wheelie. Adjusting the brake rod "loose" (~2 inch) and there's no brake and no clutch... the tractor just keeps going moving and I can easily shift between gears with or without the clutch depressed.
Is there some other adjustment to get proper clutch/brake action? Or maybe a broken clutch-side part (the brake does operate properly)? Or maybe that rod adjustment at the brake really is that "sensitive"? I'd be grateful for any ideas.
