Popping
M hopper
Hello again, while running my jd Lt166 48c 16 hp it all the sudden started making a popping sound , alot like a back fire but different. Its running fine otherwise any ideas what to look at would be appreciated.
Scrubcadet10
Moderator
Staff member
What's your engine model #? if it's an overhead valve engine it will be stamped into the metal valve cover on the front of the engine if it's a flathead it will be stamped around the sparkplug on the metal shroud, or if it's an I/C briggs the tag will be riveted to the top of the cover.
Does it do it all the time or just when you change the load on the engine by turning the blades on or changing the speed ?
