cryoburned
- May 5, 2015
- 1
- 9
Hi all,
I have a riding mower Yt 4500(Engine 445877-1565-G5) that is surging when running, dies shortly after warming up. Fuel filter changed, new air filter, spark plugs, new fuel pump. Oil was very clean but low, no visible leaks, perhaps blowing by? Anyways, I suspected the carburetor, took it off and apart to clean, and I see the intake manifold flange is warped (plastic i/m). The o rings on the runners are somewhat distorted also. I work on cars usually, and so I'm wasn't surprised to see the plastic intake manifold was warped, since car manufacturer's have mostly switched to plastic, and they have warping issues also. Anyways, I searched google for warped briggs intake, and see there are some series engines that had cast aluminum manifolds, but I need either a part number or engine model code to search through a parts list. Can anyone help me out?
Thanks
Thanks
