Plastic Carbed Lawn-Boy Question
Folks,
Easy one here:wink:, does anybody know if the main stainless steel screen-wrapped carb tube is removable?
Thanks,
Rocky
jp1961
Yeah, it should slide right off.
This is a Duraforce carb right?
It's the only fuel filter a Duraforce has,,,no screen filter in the bottom of the tank like earlier Lawn-Boys.
Regards
Jeff
Jeff,
No, this plastic carb is off my 4502 UTILITY , F340 motor which I bought new in 1981.
No, it does have a fine "nylon-esque" square screen in the corner inside the tank right above the tank shut-off valve.
I stated my original question rather poorly, does the plastic main jet tube (screen wrapped) come off, (not the screen)?:wink:
I was hoping to remove this long tube and soak/blow-out the plastic jet inside.
Thanks for any help anyone might have,:smile:
Rocky
