piston issue?
babss
my bg56c piston won't rotate beyond bdc unless i spin the flywheel in the opposite direction where it stops at bdc again. i put a new carb on because gas in the muffler and difficulty pulling the rope without wrist injury. is it worth fixing?
Probably not for a BG56 but it will only cast a bit of silicon to pull it apart
Most likely some thing has fallen down the induction tube
The bottom ends are generally a crowded race so don't give you grief
The other reason would be lumps of a broken piston.
Farmer Teck do replacement barrels & pistons for a reasonable price .
I have fitted a lot of them to various engines with good results when you get the right one ( can be a problem ) .
Pull the muffler and take a look inside. Tell us what you find.
Fish
Also take off the starter and take a peek, a loose screw could be jammed somewhere.
Hammermechanicman
Nothing to lose, try this. Remove spark plug and turn unit upside down and rotate flywheel back and forth a dozen or so times and see if the problem goes away. If there is liquid fuel in the crankcase you can get the problem you describe and it hydrolocks.
babss
the bottom of the piston is contacting the counterweights on the crankshaft. with the piston removed, I can grab the connecting rod and everything rotates smoothly. wtf?
Star hit it on the head, bearing or bushing failure. Most likely cause, unless you replaced any internal parts.
