Picking a snow removal machine
dria
I know I still have a lot of time before I do this. But I need to come up with some way to move snow. I have a long driveway and I just do not have the back for all that shoveling. What are my options?
173abn
dria,well starting with the cheapest I guess a walk behind snowblower,tractor with a fel or blade or snowblower or if you got neighbors with boys hire them to do it. russ
JDgreen
Lot of variables...how long is the driveway, gravel, grass, or paved? Do you need to have it cleared by the time you leave for work or school in the morning? What do you have in the way of lawn care equipment now? If your driveway is paved, in your region a 5 or 6 hp compact blower will probably suffice up to 100-150 feet. Longer than that, a two stage 8-10 hp will be more practical. Blowers do not work well on grass or gravel drives unless the ground is very hard frozen. If you have a decent size (20 plus hp) lawn or garden tractor, you can fit it with weights and chains on the back and install a blower or blade on the front, that will suffice for up to 10-12 inches of dry snow.
Zeroturn
We use several things for our driveway. A snowblower if it's not too bad, our 4-wheeler with a plow when it's pretty thick out there and we are in a hurry, and of course our FarmAll H with a plow on it when it's really bad out there.
KennyV
173abn, JDgreen and Zeroturn
have covered about all the best methods...
I just like thinking about moving snow when it's near 100 degrees today here in Kansas...
Thank you for the memories of winters past... Snow blowing in a heated cab ZTR... :smile:KennyV
mowsby
I also use a 4 wheeler to plow and it does a good job. I lay salt as well and that helps too. I have son though and I also get them on board with a couple shovels. Between the three of us we get the job done pretty fast.
JDgreen
Not trying to brag, but I use a Craftsman compact 5 hp blower, an '89 vintage 5 hp Craftsman dual stage blower, a 5 hp Rally front tine tiller fitted with tractor tires and a 32 inch front blade (very unusual), a Honda Foreman 450 fitted with Warn winch and 60 inch Moose County plow, and my JD with a FEL and 5 foot back blade. I got more snow removal toys than all my neighbors put together, which is why I do their driveways after a heavy snow. :biggrin:
MowTown
I have a Craftsman 9.0/26 that I bought used two years ago for heavy snow dumps. (My neighbor paid three times as much for a new Ariens, which went on the fritz on him. Borrowed mine and put his up for sale.) My two "professional" snow shovels easily handle light loads.
linda4
Well, you could buy a riding snow blower. I used to have one that worked fine. But now I just ended up buying a plow for my 4x4 pickup truck which works even better.
Rose
We live in Canada, and although we don't get as much snow here, as in some parts of the country, we can get big dumps of over a foot in one day. We have a gravel driveway, so we had to get a a Two-stage snowblower. We got a Craftsman 5.5 hp Gas Snow Thrower which does the job for use on the ground quite nicely. For the roof, we use rakes. And sometimes, we have to get up the roof on a ladder to get a big pile dislodged.
