Okay I know this is re-run but we are moving here so i posted the photo of the only slope. Rest is pretty much flat. Only .7 acres so quick job.. aside from a significant amount of weed-whacking..
Ditch "big" slope is 22 deg measured with inclinometer. On road side: 12 deg.
How should I mow this? I'm thinking run a ZTR along the road side, up from the (wet) bottom of the ditch, like one pass @ 48". And then now the 22 deg "big" slope with a small walk-behind, and then the ZTR for the rest of it. I'd keep the ZTR away from the slope like maybe 2 passes of the 22" walk-behind.
Other would be run the ZRT "down" the ditch and up to the road size, running back to the driveway. Worry would be bogging down the ZRT in the ditch. If that were to happen, not good!
Ideas??
Ideas??
