Part number for briggs flywheel key.
Beowulf
Anyone know correct part number for flywheel key on 31P677-0144-B1 ser 090513ZD83741?
Should correct part be steel or aluminum?
TIA
Scrubcadet10
Moderator
Staff member
So one is just over a hair of a half inch long, and the other is just over 1" long... if your's is still intact you might can measure it.
Beowulf
Thank you. I was just coming back to report I found it but didn't know the length. I'll try to locate one locally tomorrow and see.
The engine is before July 1, 2012 so the following applies.
