Does anyone use this on the other decks? Oregon says.
Please see the comments below:
If they are working to the customers satisfaction and fit-up correctly under the deck, then there would be no long term harm.
When we design aftermarket blades, we design them after the OEM blades that were built for that specific deck. If used on another deck that is same size and can accept the blades off-set and lifts, there is no harm.
The only difference is that a blade not designed for that specific deck, might not deliver the same results as a blade designed for it. The geometry of the blade works in-tune with the deck design for maximum airflow. Which could be a reason why it is not cutting the grass as fine as he might like it.
- For use only on Scag Velocity Plus decks
