msdeerhunter
- Apr 14, 2014
- 4
- 16
I have a B&S 26hp, model 44P777 type 0124 G1. It is about 5-6 years old. I have always had trouble with it turning over slowly. I have almost always had to "bump" the key a couple times to get the engine to turn over. Sometimes, once I got it to turn over, I would crank it for 20-30 seconds before it would fire up. I have had to replace the starter selanoid a few times. This year I figured out that it was the valves not gapped correctly. Re-gapped the valves and it turns over much easier. It will only turn over a handful of times before the battery gets too weak to turn it over. Had the battery tested and it's fine. Now, it won't start unless I spray some carb cleaner in breather. Then, it starts right up and runs perfectly. I have new air filter, new fuel filter, new plugs and new gas. The battery is about 1-1.5 years old. I'm leaning towards the starter being worn out and weak but wanted to see if anyone would have some other suggestions before I spend the $100 on a new starter. Thanks in advance!
