can i use synthetic 2 cycle mix in my 10515 and still run it at 32:1?
E earnest t bass Active Member Joined Feb 26, 2020 Threads 16 Messages 54 Mar 13, 2021 / oil #1 can i use synthetic 2 cycle mix in my 10515 and still run it at 32:1?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,681 Mar 13, 2021 / oil #2 Short answer, Yes. Most good synthetic 2-cycle oils will work in a variety of ratios, just follow the directions on the contain.
E earnest t bass Active Member Joined Feb 26, 2020 Threads 16 Messages 54 Mar 13, 2021 / oil #3 thank you
