The rocker cover is what I would suspect. But a good engine cleaning otherwise is in order too. Please if you replace the rocker cover transfer the model, type, and date code to the new cover by either stamping or engraving them. I prefer stamping vs engraving as it embosses the numbers. This make it easier the next time parts are need for the engine otherwise it is a guessing game as which parts are right.
