I have an old Toro riding lawn mower, model # 71199. The brake spring that comes from the brake bracket to the "brake arm" that comes from the brake pedal came off. In an attempt to hook it back up, like a dummy, I rolled the lawn mower on it's side, thinking I could get to it. Bad mistake. Of course oil filled the air filter compartment. I took the air filter out, cleaned out the oil the best I could, sprayed some "engine starter spray" into it, and it only cranks using the spray, then it dies. I checked the spark plug and dried it off, but still the same thing. What do I do next? Just keep trying till it finally burns out the oil, or is there something else I can do? Thanks from a dummy
