Oil Filter Relocation Kit
msdeerhunter
Does anyone have any experience using this relocation kit, #594271? I recently installed a new engine and the filter is sitting against the frame. Or does anyone know an automotive relocation kit that would work? My current filter is #695396. The engine is model #44T9770009 G1. Appreciate any help.
What is wrong with yours now? Millions of mowers out there right now cutting grass with no filter.
My story about filter relocation kits. Had a new engine in a CJ-7 Jeep. Had this great idea, to put the dual 2 quart Chevy filter relocation kit on. While the great ideas were flowing added an 800hp rated oil cooler. Long story short, one 42 cent hose clamp came loose on the highway. New engine locked up requiring another new engine. Now I run what filter came on said engine. Much cheaper and can sleep at night.
Turn the engine around sideways
Buy the correct engine for the mower
Here what the 594271 oil filter adapter looks like. Should work fine but it is costly if you can just turn the engine 90 degrees. But that may not be possible depend what equipment the OP has the new engine installed on.
