Oil filter cross reference
se3388
New guy here, I have been using Bad Boy filters for my ZTE Elite 60" for a few years and was wondering if there is a cross reference oil filter I can pick up at Wally World or O'Reillys etc.? Thanks for any info.
Steve........
Scrubcadet10
Moderator
Staff member
Oil filter number? I think it may be a Kohler?
OR just the model from the serial number of that Bad Boy mower. As you can have a Briggs, Kohler, or Kawasaki engine.
All 3 can use the same filter as the filter specs for all of them is just about identical it is just the case size that varies.
se3388
Sorry about that, I was away for a couple of days. The Kawasaki oil filter number is 49065-7007.
Steve..........
• Briggs & Stratton small version filter for 12 - 25 HP Vanguard engines, pressure lubrication engines .
• Tecumseh OHV 115 - 170, TVT691, OV and VTX.
• Kawasaki 15 - 19 HP FB460V, FC420V, FC540V, FD501D and FD590V.
• Kohler CH18 - 25, CV18 - 25.
Anti-Drain Yes
Height 2.66"
Micron 30
Outside Diameter 2.921"
Relief Pressure 10 - 20 PSI
Thread Size 3/4"-16
49065-7007 Superseded to 49065-0721
Scrubcadet10
Moderator
Staff member
Steve..........
Wix 51056 and 57035 should work, and be available at O'reilly
