Hello - I attempted to change the oil on my zero turn, however the cap on the drain tube wouldn't budge. I ended up twisting the tube so badly that it broke open. I've been able to zip tie the tube in a vertical position to avoid spillage, however I'd like to replace it. Given the frame and nature of where the tube is located I'm wondering if anyone has any advice on how to go about installing a new tube.
