Turf Tiger. SST61V35BVAC
Serial E5400225
Have a issue with the oil drain Assy on the above machine. Appears that the drain assy is leaking around the vertically oriented plug you loosen to drain the oil.
It is tight. Has anyone had this problem on this B/S 35 hp engine?
Thanks for your comments.
Knots
Serial E5400225
Knots
