What is the amount of oil needed on a kohler vanguard 993cc engine when changing filter also
M MikeN5660 Forum Newbie Joined Mar 28, 2023 Threads 1 Messages 1 Mar 28, 2023 / Oil capacity Bad Boy Kohler 993cc #1 What is the amount of oil needed on a kohler vanguard 993cc engine when changing filter also
H hlw49 Lawn Addict Joined Jul 11, 2021 Threads 35 Messages 1,374 Mar 28, 2023 / Oil capacity Bad Boy Kohler 993cc #2 Kohler does not make a Vanguard engine, that would be a Briggs.
I ILENGINE Lawn Pro Joined May 6, 2010 Threads 39 Messages 9,865 Mar 28, 2023 / Oil capacity Bad Boy Kohler 993cc #3 2.0-2.7 US quarts. Straight from the owners manual,
B Bertrrr Well-Known Member Joined Mar 11, 2021 Threads 4 Messages 391 Mar 29, 2023 / Oil capacity Bad Boy Kohler 993cc #4 Just add till it gets to the full mark , run a few minutes and recheck - some of these engines say just stick the dip stick in the fit and do not screw it all the way down
D dave77 Forum Newbie Joined Jul 15, 2014 Threads 0 Messages 2 Apr 8, 2023 / Oil capacity Bad Boy Kohler 993cc #5 try this web page, it has the specs for your motor. https://www.vanguardpower.com/na/en...engines/big-block-vtwin-horizontal-shaft.html
