hrdman2luv
- Aug 23, 2014
- 62
- 345
I have a 21hp briggs, model #407777-0167-E1. There's only a cap where the oil filter should be. Since I have so much to mow (probably 8+ acres) seems a little extra protection (installing an oil filter) would be necessary. I run Mobil 1 synthetic in it. But would like to adapt an oil filter to it...
Question: Is there an internal oil pump in models that already have oil filters? Or do they all come with an oil pump, and so just adding the necessary threaded extension to install an oil filter be OK? If it doesn't have an oil pump, would I need to take the engine apart to install one?
Or is this just a waste of time. I understand that oil filters only job is to clean the oil. And so, changing the oil more frequently is OK. But, the synthetic oil is so expensive. I was hoping that I could not only save time and money on oil changes. But also keep the oil cleaner..
Any suggestions?
Any suggestions?
