No fuel to filter
Smitty57
No fuel to filter? BandS 19HP intek , new fuel pump, filter, cleared the lines from tank, had to put gas in, I haven’t ran it in a month could there be debris blocking the lines in the tank?
Yes.
Pull the fuel line from the pump
remover the filler cap
Shove an airline into the tank and block off the filler neck with you hand so it will be leaky.
A modest amount of air should have the fuel line running like a hose.
Anything short of gushing = blockage in the fuel tank or line.
Also make sure the pump is connected properly
Impulse line is the one on the flat face the input line in the one underneath & the output is on the opposite side.
