No forward or reverse
Coach Dave
husqvarna YTH22V46 will not move forward or reverse. All belts checked and are installed properly. I can see the drive belts moving with a driver on the mower. Is there anything I can check while I have the deck off and out of the was. This is an automatic transmission.
Check that the bypass ( push the mower ) valve is in the mow & not push position
On most Huskies that would be pushed FULLY in
Debris can accumulate around the lever preventing it moving all the way
