howdydoody
- Mar 6, 2020
- 1
- 6
Model 17af2acp001
Serial 1d088g20302
Jumper cables to bat- starter+ = start and runs. Replaced solenoid after it tested bad with used one I had after it passed bench test(auditable click with continuity across big post). Both are 4 wire. Will not click after installation this starter doesn't engage. First small tab,orange wire sends 7.5 volts with key in start position. Is this enough? Second small tab,green wire has ground. Did notice when key is in start position the PTO/blade light illuminates. That's not correct is it?
I might add,the gifter originally started repair of PTO wouldn't engage,he went on to replace wiring harness(I'm praying with the correct one)
Thanks in advance for any comments from anyone who takes time to share there time and knowledge
Serial 1d088g20302
