I just picked up a used YTH24K48 that I have no history about except it quit running while cutting and the guy parked it. No fuse was blown or wiring altered before I got the mower he said.
When I got it the battery was dead and it recharged and fired up. PTO does not engage but switch has continuity through it as it supposed to when up or down.
Testing based off the A1 spot off the ignition I would this this should be 12v positive output but it is 12v ground tested with continuity and test light. Blue wire that goes to spot A on the PTO switch.
When I run a new direct wire off of positive battery in place of the blue wire the PTO engages.
Any help to get this mower correct will be great.
