New Z345R won't start after turning on a hill
zeroturnnewb
I was mowing this evening and I was coming down a slope. I tried to make a small turn and my zero turn shut off. I thought it was just a safety thing that turned off the engined because I was trying to make a turn downhill. After that, I couldn't get it to start. It won't crank and the display is completely blank. It's almost like the battery is dead but this mower is only 2 months old. Any ideas? Thanks in advance.
Check the battery leads at both ends
Check the fuse
Let us know what you find
zeroturnnewb
Check the fuse
I looked at the fuses and the 7.5a fuse was blown. Going to try and find a replacement at lunch and I'll report back. Thanks for the advice!!
zeroturnnewb
I found a replacement fuse and installed it. It started right up. Thanks again!
