Wetstuff
- Oct 2, 2021
- 1
- 1
I ran around the yard a bit after bringing this <500hr, used unit home. First time zero turning, and already a question.. I typically run an old 46" Craftsman up the edge of the lane then use a 6' flail mower on the pasture. But, with the Kubota, I got 'rows' of semi-cut that may match the spindles of the two outer blades...H'mmm?!.
I first thought - 'going too fast?', but then slowed with similar results. The blades are reportedly new. I am two weeks back two weeks from cervical surgery, so I cannot like lift-the-deck to see. I also thought about the RPMs ...the flail does not work worth a damn if the tractor RPMs are not >2500. Even at WOT ..I cannot judge the RPMs of this Kohler engine. So give me your thought on the odd cut
...then tell me if you have found an add-on Tach. Thanks. Jim
