New tires for Poulan Pro 22 HP
Freedom
Hello all
I have a Poulan Pro, 4 years use, 280 hours and I must change 2 front tires. The area where I use the mower is not an easy one and the mower has too many punctures!
The tractor has installed Carlisle 15x 6 x6
I would like to receive some recommendations:
1)Tubeless is a good option for this type of yard?
2)I think there are "normal" tires and "stronger" tires, i do not find the stronger ones in Amazon, how are they called?
3) Which brand would you recommend? Oregon, Carlisle?
Thanks!
I would appreciate a fast answer because I am traveling to USA
Brand seems to make little difference I usually fit whatever is the cheapest at the time
Only criteria for me is a 4 ply tyre
Getting a case off a 6" rim is difficult so I always it tubeless tyres
That way they can be plugged without removing the case from the rim
One customer has better than 80 plugs in his front tyre .
He has Bouganvillias all over his yard & a bad habbit of pruning them but leaving the branches on the grass to get mowed over
Invest in MOWER tyre plug, they are different to car ones.
Car ones need heat to set fully mower oned don't and you can put them in the tyre while the wheel is still on the mower .
