so my new (this spring) HRNPKA spills fuel out of the carb, when not running level? mowed yesterday afternoon, no change to my little lawn, except it was a little thicker, from all the rain. stopped to clean under the deck, when I leaned the mower over onto the carb side, it started to dump fuel on the lawn? also, a small part of my yard has a slight decline, and when I pushed that area (carb side down), it started to leak fuel?? after finishing the job, I pulled the air cleaner and housing off to expose, tilted the mower carb side down, and literally started dumping fuel right out of the throat of the carb???
