New High-lift blades hitting bottom of deck 42 inch mower.
flipsworld
  • / New High-lift blades hitting bottom of deck 42 inch mower.
I just installed a bagger on a 42 inch Husqvarna and got new high-lift blades also. The blade on the discharge side is just hitting the deck right by the opening. I have no problem with regular blades. The high lifts are installed properly and I can't find anything wrong with the spindle( no give or wobbles, seems tight as it should be) Any ideas before I just throw some new regular blades back on? Thanks
Give the deck a little mechanical rectification with a 4 lb hammer
