new Broadmoor Question about 12 volt power plugin
mulch246
  • / new Broadmoor Question about 12 volt power plugin
The dealer/owner told me I can run the pump on a tow behind sprayer with this, and his mechanic says its to light duty it was meant for charging cell phones, I hope the dealer is correct?
When I asked if Briggs has the loose male plug available that i can splice on to my leads from my sprayer, he says no go to an auto supply, what is the proper name for the male end of this and can I run my
sprayer with it or will it be to much amp. draw. The sprayer is a light duty 100 liter country time from tractor supply . Thank you
I think if you google 12V accessory plug adapter you will find what you want. I run my sprayer using one on my tractor all the time. The mechanic needs to upgrade his electrical knowledge.
mulch246
I agree thanks for your input
