Carscw
- Aug 11, 2011
- 66
- 6,375
After learning how to adjust the valves from you tube, not very hard to do I learned, I tried to start it and now its totally different symptoms. The solenoid is just clicking on once when I turn key to start. No attempt at rotation of motor. Battery is new, solenoid is passing 12+ to the starter and the little wire on the solenoid when I turn to start. I haven't taken grounds apart yet to clean, but they do look and feel good. The valves were very tight. Couldn't even get .002" in them. I feel I adjusted valves correctly, but don't think that would cause this new problem anyway nor the bad grounds if they existed would they. After all, before it tried to turn over but dragged. Mmmmmmmmmmmmmm?
I know you said the battery is new. So just for fun run same jumper cables from the car battery to the mower battery.
And give it a try.
